[GRASS5] 5beta11pre1 configure failure on mac osx pb
Markus Neteler
neteler at geog.uni-hannover.de
Thu Jan 25 12:21:26 EST 2001
On Thu, Jan 25, 2001 at 10:31:22AM -0600, andy agena wrote:
> hi markus:
> Is there any chance to compile the mathlib extra with c-compiler?
> how do i go about doing this?
Well, I don't know much about this. Usually I would expect that
libm comes along with the compiler. Perhaps you compile
"gcc" (www.gnu.org), then you should have it. But how can Mac
work without this lib??
Probably it is just in a place where configure doesn't look.
> > checking for gcc... no
> checking for cc... cc
Aha!
> checking whether the C compiler (cc ) works... yes
> checking whether the C compiler (cc ) is a cross-compiler... no
> checking whether we are using GNU C... yes
> checking whether cc accepts -g... yes
> checking how to run the C preprocessor... cc -E -traditional-cpp
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
