[GRASS5] XDRIVER problem
Radim Blazek
Radim.Blazek at dhv.cz
Thu Jan 25 13:55:07 EST 2001
I have some problems with XDRIVER:
GRASS:~ > d.mon start=x1
using default visual which is TrueColor
Visual is read-only or using a private colormap
ncolors: 32768
allocating memory...
Graphics driver [x1] started
Please start graphics monitor <x1>.
Error - Graphics monitor <x1> not running!
(But monitor window is opened)
GRASS:~ > d.mon select=x1
One week old version seems to work well.
I have similar problem on two computers.
The source is fresh from CVS. (Linux RH6, KDE1)
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
