[GRASS5] pre-test GRASS 5beta11pre1
Bernhard Reiter
bernhard at intevation.de
Thu Jan 25 10:00:13 EST 2001
On Thu, Jan 25, 2001 at 02:48:39PM +0000, Markus Neteler wrote:
> On Thu, Jan 25, 2001 at 02:15:40PM +0100, Bernhard Reiter wrote:
> > Didn't you plan to only release a source tarball, so that
> > only developer can really pretest?
> O.k., I will delay the binaries as requested.
> But the binaries should be tested as well, therefore I was thinking
> to publish the as "beta11pre1".
As we do expect minor configuration bugs in the beta11pre1 release,
the binaries will change anyway. There is no point in releasing
them, because the target audience should be able to produce binaries
anyway.
Bernhard
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20010125/26fc3031/attachment.bin
