[GRASS5] pre-test GRASS 5beta11pre1
Markus Neteler
neteler at geog.uni-hannover.de
Thu Jan 25 09:48:39 EST 2001
On Thu, Jan 25, 2001 at 02:15:40PM +0100, Bernhard Reiter wrote:
> I am sorry, I have hit the wrong button sending this to the list.
> (That's why it is in German. Here is a rough translation.)
> Hello Markus,
> thanks for the hard work.
> Please make the Warning in the ftp directory more visable.
> Didn't you plan to only release a source tarball, so that
> only developer can really pretest?
O.k., I will delay the binaries as requested.
But the binaries should be tested as well, therefore I was thinking
to publish the as "beta11pre1".
Markus
> On Thu, Jan 25, 2001 at 02:09:23PM +0100, Bernhard Reiter wrote:
> > Hallo Markus,
> > danke für die Arbeit:
> > Bitte mach die Warnung in dem ftp Verzeichniss deutlicher!
> > Wolltest Du nicht nur sourcen rausgeben, damit sich nur wirklich die
> > Entwickler dran beteiligen?
> > Bernhard
> > On Thu, Jan 25, 2001 at 01:33:53PM +0000, Markus Neteler wrote:
> > > time has come to publish beta11... :-)
> > > http://www.geog.uni-hannover.de/grass/grass5/source/
> > > I would like to ask you to test this tarball.
> > > For Linux I will put out a binary tarball later this day.
> > > NOTE:
> > > The LZW-compression is removed from GRASS floating point
> > > raster maps and G3D maps. Means: You have to convert
> > > *all* FP and G3D maps. Plain CELL (Integer) maps are not affected.
> > > See announcement and link to conversion tool here:
> > > http://www.geog.uni-hannover.de/grass/announces/announce_lzw_removal.html
> > > The conversion tool r.lzw2z runs pretty well now.
> > > Thanks in advance for testing the new package,
> > > Markus
> > > Markus Neteler * University of Hannover
> > > Institute of Physical Geography and Landscape Ecology
> > > Schneiderberg 50 * D-30167 Hannover * Germany
> > > Tel: ++49-(0)511-762-4494 Fax: -3984
> > > If you want to unsubscribe from GRASS Development Team mailing list write to:
> > > minordomo at geog.uni-hannover.de with
> > > subject 'unsubscribe grass5'
> > Professional Service around Free Software (intevation.net)
> > The FreeGIS Project (freegis.org)
> > Association for a Free Informational Infrastructure (ffii.org)
> > FSF Europe (fsfeurope.org)
