[GRASS5] r3.showdsp-NVIZ
Helena Mitasova - staff
helena at gis.uiuc.edu
Wed Jan 24 08:58:33 EST 2001
>I assume that the "mkdsp" stuff and probably the volume display is
>already integrated in above NVIZ/GL versions.
Unfortunatelly, it is not. The volume display is in sg4d which is quite
different from NVIZ but I will try to find it too - it may still
be useful. Mark Astley managed only to write the
interface for linking in r3.showdspf and r3.makedspf but the actual
integration was not done.
>So we might not concentrate
>an r3.showdspf as a stand-alone module, but try to integrate r3.mkdspf/
>r3.showdspf into the NVIZ2.2/openGL. Of course this will be much work.
that is correct, Bill says it should not be too difficult (which does not mean
that it won't be much work). I will try to find everything that could help with it.
Helena
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
