[GRASS5] rlzw-ssurfrst
Helena Mitasova - staff
helena at gis.uiuc.edu
Tue Jan 23 12:57:04 EST 2001
>The problem with s.surf.rst is that it doesn't use the GRASS functions
>to write maps (huh!). Therefore the lzw_compression_bits: 0 occurs.
>The module uses "fwrite" as far as I understand
>src/sites/s.surf.rst/main.c
>Maybe I am wrong and src/libes/rst_gmsl/interp_float/output2d.c is
>used with G_put_f_raster_row().
yes, all output raster maps from s.surf.rst are
written in src/libes/rst_gmsl/interp_float/output2d.c by G_put_f_raster_row()
>Ah yes, see
>./interp_float/resout2dmod.c
>./interp_float/resout2d.c
> cf1 = G_open_fp_cell_new_uncompressed (params->elev);
>Maybe that's the reason?
resout.c is not used by s.surf.rst but it is for r.resamp.rst
(see IL_resample_output_2d)
see DESCRIPTION.INTERP what each function does.
The problem may be that s.surf.rst was ported to FP before
FP was stable so it may contain some relics from older versions
of FP implementation. Although I don't understand why elevation is
OK and slope and curvatures are not, because they are written the same way,
(at least as far as I can tell).
Helena
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
