[GRASS5] r.lzw2z updated...
Markus Neteler
neteler at geog.uni-hannover.de
Tue Jan 23 13:10:57 EST 2001
On Tue, Jan 23, 2001 at 08:40:53AM -0800, Eric G . Miller wrote:
> On Tue, Jan 23, 2001 at 09:42:47AM +0000, Markus Neteler wrote:
> [snip]
> > Processing pcurv at hude ... Copying ... Done!
> > WARNING: No lzw_compression_bits value in
> > /home/neteler/grassdata5/hude/hude/cell_misc/tcurv/f_format
> > Skipping raster tcurv at hude -- Not LZW compressed
> > /home/neteler/grassdata5/hude/hude/cell_misc/mcurv/f_format
> > Skipping raster mcurv at hude -- Not LZW compressed
> > /home/neteler/grassdata5/hude/hude/cell_misc/pcurv_rst/f_format
> > Skipping raster pcurv_rst at hude -- Not LZW compressed
> > The files with WARNING now have a f_format entry like this:
> > more f_format
> > type: float
> > byte_order: xdr
> > lzw_compression_bits: 0
> > What does this indicate? Was it an uncompressed file (the map was generated
> > with s.surf.rst) ?
> > The map is corrupted now:
> > d.rast tcurv
> > WARNING: error reading compressed map [tcurv] in mapset [hude], row 91
> > Maybe that's the last bug...
> Try changing the lzw_compression_bits to something like "9" and
> re-running the r.lzw2z script. Note: r.lzw2z wouldn't have touch the
> f_format file (except to read) if it said it skipped the file. The
> problem seems to be that somehow s.surf.rst writes an lzw compressed
> file but lzw_compression_bits is not set correctly (should be between 9
> and 20). Not sure how that would happen. The reason to have these
> tests of lzw_compression_bits is so the program doesn't even try to read
> non-LZW compressed rasters (which would always fail and cause the
> program to exit). But, then it has to rely on lzw_compression_bits
> being set to a valid value in order to make the determination (it seems
> to be the only indicator of LZW compression). The maps are probably not
> corrupted, just LZW compressed with a bogus lzw_compression_bits number.
A good idea! I have changed the f_format and re-run the converter.
r.lzw2z then runs well:
r.lzw2z slope_rst
Processing slope_rst at hude ... Copying ... Done!
and I can even display the map.
The problem with s.surf.rst is that it doesn't use the GRASS functions
to write maps (huh!). Therefore the lzw_compression_bits: 0 occurs.
The module uses "fwrite" as far as I understand
src/sites/s.surf.rst/main.c
Maybe I am wrong and src/libes/rst_gmsl/interp_float/output2d.c is
used with G_put_f_raster_row().
Ah yes, see
./interp_float/resout2dmod.c
./interp_float/resout2d.c
cf1 = G_open_fp_cell_new_uncompressed (params->elev);
Maybe that's the reason?
Could you change the r.lzw2z accordingly so that it can handle these
data as well without WARNING?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
