[GRASS5] GRASS and backspace key
Roger S. Miller
rgrmill at rt66.com
Thu Jan 18 11:50:46 EST 2001
On Thu, 18 Jan 2001, Markus Neteler wrote:
> Hi all,
> another annoying thing is that GRASS has some problems
> with backspace key. If you enter a map name, it will
> result to this:
> VECTOR (DIGIT) FILENAME
> Enter 'list' for a list of existing binary vector files
> Hit RETURN to cancel request
> > linien^H^H^H^H^H
Try ctrl-backspace.
Just now I wasn't able to find a command that gave me that problem while
running Linux and testing with the KDE desktop and fvwm2 window manager or
with OS/2 with the ICE window manager. I've seen it (plenty) before and
found it very frustrating. In all cases I've found if backspace doesn't
work then ctrl-backspace does.
Roger Miller
Lee Wilson and Associates
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
