[GRASS5] projection-transformation
Markus Neteler neteler at geog.uni-hannover.de
Thu Jan 11 12:24:13 EST 2001
Hi Michel,
On Thu, Jan 11, 2001 at 03:49:29PM +0000, Michel Wurtz wrote:
> Markus Neteler wrote:
> > Hi Michel,
> > I have received another SHAPEfile with borders which matches quite good
> > to my other data. So three options are there:
> >  - mistake done by the students
> >  - e00 needs Xshift and Yshift set
> Well, this is probably easy to handle, but I need some example for
> this (the questions is : does we apply shift before or after scaling ?)
> >  - general ArcInfo problem (btw: it was PC3.5, not 8)
> For the two other options, I can't do anything ;-)
I have investigated some more hours...
Here the results:
 - we have used "projectdefine" to add a projection in ARCINFO8
   (using the PC-ARCINFO3.5 e00 file)
-> import into GRASS is identical. The misplacement is *non-linear*.
While thinking about the problem I should describe the input dataset better:
The students have digitized the country's border from a 1:500000 paper map
of Lower saxony. Problem with this map is:
 - the map is projected in Lambert Conical projection (10:30E meridian)
 - the border's coordinates are given in degree, nothing else
 - ellipsoid is "international"
Now the students have referenced the map to lat/long and digitized.
The misplacements are like that (compared with an other digital governmental
dataset and the GSHHS shorelines):
 6°         7°         8°         9°        10°        11°
 +          +          +          +          +          +  53:30°
  north sea    ***(islands)  ***                  -----
 |   shift: 2.5km to E                                     |  + 53 E
 |          500m  to S
 |                                                 shift: +/- 0
/                   LOWER SAXONY (northern Germany)
|                                                              + 52 E
\    shift: 1km to W (!)                                     |
 \          0 to S                                           /
                                         shift: 1.5km to E      + 51 E
                                                2km   to S
Let me say: I am slightly confused.
Perhaps the problem is that the map's projection is Lambert, but GRASS
et al. treat is as Geographic (lat/long)? But, then, how to get in
a map projection in Lambert if only lat/long coordinates are printed on
that map?
I am quite in the dark,
help is appreciated (especially to save the digitizing work)
 Thanks for listening!
   Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
