[GRASS5] projection-transformation
Michel Wurtz mw at teledetection.fr
Thu Jan 11 10:49:29 EST 2001
Markus Neteler wrote:
> Hi Michel,
> I have received another SHAPEfile with borders which matches quite good
> to my other data. So three options are there:
>  - mistake done by the students
>  - e00 needs Xshift and Yshift set
Well, this is probably easy to handle, but I need some example for
this (the questions is : does we apply shift before or after scaling ?)
>  - general ArcInfo problem (btw: it was PC3.5, not 8)
For the two other options, I can't do anything ;-)
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
