[GRASS5] configure-problem on linux and irix
Andreas Lange Andreas.Lange at Rhein-Main.de
Sat Jan 6 08:00:34 EST 2001
there must be some small errors with configure.
configure no longer finds GLwMDrawA.h, which was found with the same
setup once before (file irix-configure contains all switches i used to
compile a perfectly working bin installation on irix 6.5/with gcc).
And there must be some typo around line 3404 in configure.
Please see the attached files.
cu,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
./configure --bindir=/usr/people/andreas/bin \
--enable-postgres=no \
--with-jpeg-includes=/usr/freeware/include \
--with-jpeg-libs=/usr/freeware/lib32 \
--with-tiff-includes=/usr/freeware/include \
--with-tiff-libs=/usr/freeware/lib32 \
--with-tcltk-includes=/usr/freeware/include \
--with-tcltk-libs=/usr/freeware/lib32 \
--with-opengl-includes=/usr/include \
--with-opengl-libs=/usr/lib32
creating cache ./config.cache
checking host system type... mips-sgi-irix6.5
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking whether ld -s works... no
checking for a BSD compatible install... /usr/freeware/bin/install -c
checking for flex... flex
checking for yywrap in -lfl... no
checking for ranlib... :
checking for env... env
checking for f77... f77
checking how to run the C preprocessor... gcc -E
checking for X... libraries , headers
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for ANSI C header files... yes
checking for curses.h... yes
checking for limits.h... yes
checking for termio.h... yes
checking for termios.h... yes
checking for unistd.h... yes
checking for values.h... yes
checking for zlib.h... yes
checking for sys/ioctl.h... yes
checking for sys/mtio.h... yes
checking for sys/resource.h... yes
checking for sys/time.h... yes
checking for sys/timeb.h... yes
checking for sys/types.h... yes
checking for sys/utsname.h... yes
checking whether time.h and sys/time.h may both be included... yes
checking for off_t... yes
checking for uid_t in sys/types.h... yes
checking for Cygwin environment... no
checking curses.h WINDOW structure component... _maxy
checking for ftime... yes
checking for gethostname... yes
checking for gettimeofday... yes
checking for lseek... yes
checking for nice... yes
checking for time... yes
checking for uname... yes
checking for seteuid... yes
checking for setpriority... yes
checking for setreuid... yes
checking for setruid... yes
checking whether setpgrp takes no argument... yes
checking for initscr in -lncurses... no
checking for initscr in -lcurses... yes
checking for gtty in -lcompat... no
checking for tgetent in -ltermlib... yes
checking for xdrmem_create in -lsun... yes
checking for xdrmem_create in -lc... yes
checking for deflate in -lz... no
checking for atan in -lc... no
checking for atan in -lm... yes
checking for dlsym in -ldl... yes
checking TIFF include dirs...  -I/usr/freeware/include
checking additional TIFF library dirs...  -L/usr/freeware/lib32
checking for TIFFOpen in -ltiff... yes
checking Tcl include dirs...  -I/usr/freeware/include
./configure[3404]: test: argument expected
checking Tk include dirs... -I/usr/freeware/include
checking additional Tcl and Tk library dirs...  -L/usr/freeware/lib32
checking for Tk_MainWindow in -ltk8.0... yes
checking GL/gl.h and GL/GLwMDrawA.h... configure: warning: *** Didn't find GL/GLwMDrawA.h
 -I/usr/include and
checking for glBegin in -lGL... yes
checking for gluBeginCurve in -lGLU... yes
checking for GLwDrawingAreaMakeCurrent in -lGLw... no
checking for GLwCreateMDrawingArea in -lGLwM... no
checking for sql.h... no
checking for jpeglib.h... yes
checking for jpeg_start_compress in -ljpeg... yes
updating cache ./config.cache
creating ./config.status
creating Makefile
creating src/CMD/head/head
creating src/include/config.h
src/include/config.h is unchanged
