[GRASS5] new vector2
Radim Blazek
Radim.Blazek at dhv.cz
Fri Jan 5 08:02:53 EST 2001
Justin Hickey wrote:
> Hi Radim
> Radim Blazek wrote:
> > My conclusion is:
> > - vector file may ben written in big or little endian (no pdp or
> > other) and byte order is specified in header
> > - by default new file will be written in machine native byte order
> > (later add optional byte order for new files by enviroment
> > variable GRASS_VECTOR_ENDIAN)
> > - vector modules (library) will work with both little and big endian
> > vector files
> > - write new module for conversion little <=> big
> > - no auto conversion into native format (read only files, files shared
> > by more platforms)
> > - vector written in one byte order (big for example) will be updated
> > in that byte order (big) even on machine with some other byte order
> > (little)
> Hmmm. I don't understand why you need to maintain the byte-order of a
> file, or provide the users with a new module. It seems to me that it
> would be easier (less work) to write a conversion function in the vector
> library that checks the byte-order and converts it to the machine
> byte-order if necessary. Write will always write in native format. Then
> the conversion is only performed when necessary, the user never knows
> the difference, and grass will always be able to read either format
> making the files platform independent. It seems to me that in this case
> the only task here is to write a single "check and convert" function for
> reading vector files. Am I missing something?
Yes. That is what I mean by: vector modules will work with both orders.
Conversion module may be used to increase speed if files are not in native
order.
Radim
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
