[GRASS5] new gmake system
Markus Neteler neteler at geog.uni-hannover.de
Thu Jan 4 11:55:23 EST 2001
Hi Andreas,
On Thu, Jan 04, 2001 at 02:48:04PM +0100, Andreas Lange wrote:
> Hi again,
> the new gmake system works very nice. Thanks a lot.
> But some thinks should be noted in the INSTALL file:
> If you compile grass on a clean system, gmake5 is installed only with
> 'make install'. So if the compile ('make') is finished and you try to
> compile g3d and/or the postgreSQL modules, gmake5 is not found.
> Compiling with bin.$ARCH/gmake5 does not work (not found error).
Justin, may I ask you to take over this one?
> I can no longer compile src.contrib/GMSL/g3d, the -lXm library and
> headers are not found any longer.
> I did:
> ln -s /usr/X11R6/LessTif/Motif1.2/include/Xm /usr/X11R6/include/Xm
> The headers are found now, but not the library.
> I have around:
> /usr/X11R6/lib/libXmu.so.6
> /usr/X11R6/lib/libXmu.so.6.1
> /usr/X11R6/lib/libXm.so.2
> /usr/X11R6/lib/libXm.so.2.1
> /usr/X11R6/lib/libXmu.a
> /usr/X11R6/lib/libXm.so.1
> /usr/X11R6/lib/libXm.so.1.0.2
> /usr/X11R6/LessTif/Motif1.2/lib/libXm.a
> /usr/X11R6/LessTif/Motif1.2/lib/libXm.la
> /usr/X11R6/LessTif/Motif1.2/lib/libXm.so
> /usr/X11R6/LessTif/Motif1.2/lib/libXm.so.1
> /usr/X11R6/LessTif/Motif1.2/lib/libXm.so.1.0.2
> Where to change the path?
Please try to add the path in
configure                    Row 3195
(my_lib_dirs)
If that helps, Eric (or me or you) could add it in configure[.in].
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
