[GRASS5] man/ directory
Eric G . Miller
egm2 at jps.net
Thu Jan 4 04:07:57 EST 2001
On Thu, Jan 04, 2001 at 09:24:15AM +0000, Markus Neteler wrote:
> On Thu, Jan 04, 2001 at 02:54:19PM +0700, Justin Hickey wrote:
> > Hello Markus, and Bernhard
> > I just did a fresh cvs checkout and the man/ directory and several of
> > it's subdirectories were created. If I remove the man/ directory and do
> > a "cvs update man" it doesn't come back. Any ideas what is going on?
> Hi Bernhard and Justin,
> a fresh cvs does *not* contain /man here (on my linux box).
> I have
> Concurrent Versions System (CVS) 1.10.7 (client/server)
> Maybe some SGI specific bug in cvs? Even on Solaris is doesn't appear (I am
> using there: Concurrent Versions System (CVS) 1.9 (client/server)).
> Sorry, no idea,
Use "cvs update -dP" or "cvs checkout -P".
A fresh normal cvs checkout will get those empty directories, but the
"-P" option should remove any directories that don't have any files.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
