[GRASS5] Gmakefiles - $(VECTLIB) question
Justin Hickey
jhickey at hpcc.nectec.or.th
Thu Jan 4 03:46:10 EST 2001
Hi Markus
Markus Neteler wrote:
> > It is definitely unusual, and the module did compile before. Look at
> > what has changed since the last version of the Gmakefile to see what
> > is causing the problem. Maybe we can get a hint from that.
> Well, Radim had to use a similar trick:
> $(CC) $(LDFLAGS) -o $@ $(LIST) $(VECTLIB) ... $(VECTLIB_REAL)
> $(DIG2LIB) ...
> So that's even not what it should be.
Then for now, I would recommend leaving it the way you had it. We will
have to try and find out what to do when two libraries depend on each
other.
> > BTW, I am currently changing all Gmakefiles that have VASK. VASK was
> > basically $VASKLIB $CURSES, and $CURSES was some -l stuff (eg
> > -lncurses) so I deleted VASK from make.mid and am changing all VASK
> > references to VASKLIB and adding CURSES to the compile line (just
> > before MATHLIB).
> Yes, that's the correct way. Thanks for doing this job,
No problem.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
