[GRASS5] projection-transformation
Markus Neteler neteler at geog.uni-hannover.de
Wed Jan 3 06:32:47 EST 2001
On Wed, Jan 03, 2001 at 11:00:21AM +0000, Michel Wurtz wrote:
> Markus Neteler wrote:
> > Merry Christmas to all!
> Thank you, and have a happy new millenium (guess you won't be
> here for the next one ;-)
I'll try my very best :-)
> > BTW: I have sent my ARCINFO map to Michel for investigation. Perhaps he can
> > find the problem in the e00 file (Michel: You have the red line dataset,
> > above west corner point in lat/long is 7:08:31.53E 53:42:41.51N).
> > Final test: I have transformed my west corner point to lat/long:
> >  - it matches gshhs dataset
> >  - it doesn't match ARCINFO
> Well, the e00 file seems OK, but doesn't contain any projection
> information (no "PRJ" section).  What say Arc/Info about the west
> corner point's lat/long ?  Maybe there is some information that
> is not exported in the e00 file, like scale or east/north shift.
> Try to export with a PRJ section (it contains values names Scale,
> Xshift and Yshift that may be usefull here) and send me the e00
> file again if you can.
Aehm - any hints how to do that? Otherwise I'll read the instructions.
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
