[GRASS5] Gmakefiles cleaned
Markus Neteler neteler at geog.uni-hannover.de
Wed Jan 3 06:07:05 EST 2001
On Wed, Jan 03, 2001 at 03:40:39PM +0700, Justin Hickey wrote:
> Hi Markus
> Markus Neteler wrote:
> > Hi all,
> > currently I am cleaning the Gmakefiles:
> > - adding  PGM=... if required
> > - adding LIBES=... if more than two libs
> > - remove unused stuff
> > Beside 20% of src/raster/ and src/sites/ the src/ tree is
> > finished. I'll continue next year.
> > Maybe we can add the
> >  install:
> > target later in a (semi-)automated way.
> I'll volunteer to try and automate it once you're done.
Hi Justin,
o the entire src/ is done with a few exceptions (where two or more
  targets exist in one Gmakefile). I don't know how to update here.
o Part of src.contrib/ is also done, but I got tired... There are too
  many unused modules. The relevant modules listed in lists/GRASS should
  be done, too.
o src.garden/ should be o.k. as well.
I have, when required, re-ordered the MATHLIB XDRLIB and checked/added
LIBES= lines in case of more than two GRASS libraries. Other rubbish
was removed. So the Gmakefiles should be in a good condition now.
If you manage to update by script would save much time. The few failing
Gmakefiles we can do by hand.
Thanks for your help
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
