[GRASS5] Monitor Resize Problem
Bob Covill
bcovill at tekmap.ns.ca
Wed Jul 18 18:43:17 EDT 2001
Glynn Clements wrote:
> Bob Covill wrote:
> > This is probably a question for Glynn. I grabbed a recent copy of
> > GRASS-5 from the CVS yesterday and built it on my Sun (ultra II) with
> > Solaris 7.
> > It was configured (for the build) with the flag "--enable-postgres=no".
> > No other configure flags were used. GRASS built fine with no complaints,
> > however after I start a monitor it cannot be resized. I have built other
> > beta versions on the Sun with no problmes with the monitor. This seem
> > sto be something new in the latest version (or something that I am doing
> > wrong?)
> How old was the previous (working) version?
> This would appear to be related to changes made between 2001/05/08 and
> 2001/06/04.
> The idea is that the window can't be resized while a client is
> connected to it. The reason being that the window is redrawn following
> a resize, which requires re-running the commands which were registered
> with D_add_to_list, and you can't have multiple clients connected
> simultaneously.
> It should be possible to resize the window when no client is connected
> though.
> Also, which window manager are you using? Does the problem go away if
> you use a different WM? What does "xprop" say about the window's
> WM_NORMAL_HINTS property?
> Glynn Clements <glynn.clements at virgin.net>
Glynn,
The CVS entries from the last build I did on the Sun are from May 21,
2001.
The window manager I am using on the Sun is the dtwm, part of the
Solaris install. I do not know the version number off hand, but it is
the one packaged with Solaris 7, if that helps.
Below is the output from xprops on the monitor ....
WM_STATE(WM_STATE):
window state: Normal
icon window: 0x3404224
_DT_WORKSPACE_PRESENCE(_DT_WORKSPACE_PRESENCE) = 0x101
WM_PROTOCOLS(ATOM): protocols WM_DELETE_WINDOW
WM_CLASS(STRING) = "x0", "GRASS 5.0.0pre1"
WM_HINTS(WM_HINTS):
bitmap id # to use for icon: 0x6800002
WM_NORMAL_HINTS(WM_SIZE_HINTS):
program specified size: 450 by 400
WM_CLIENT_MACHINE(STRING) = "tekmap"
WM_COMMAND(STRING) = { "x0" }
WM_ICON_NAME(STRING) = "GRASS 5.0.0pre1 - Monitor: x0"
WM_NAME(STRING) = "GRASS 5.0.0pre1 - Monitor: x0"
If there is any other info. I can provide, let me know. Thanks in
advance for your help.
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
