[GRASS5] Monitor Resize Problem
Bob Covill bcovill at tekmap.ns.ca
Wed Jul 18 20:02:47 EDT 2001
Glynn Clements wrote:
> Bob Covill wrote:
> > > > This is probably a question for Glynn. I grabbed a recent copy of
> > > > GRASS-5 from the CVS yesterday and built it on my Sun (ultra II) with
> > > > Solaris 7.
> > > > It was configured (for the build) with the flag "--enable-postgres=no".
> > > > No other configure flags were used. GRASS built fine with no complaints,
> > > > however after I start a monitor it cannot be resized. I have built other
> > > > beta versions on the Sun with no problmes with the monitor. This seem
> > > > sto be something new in the latest version (or something that I am doing
> > > > wrong?)
> > > How old was the previous (working) version?
> > > This would appear to be related to changes made between 2001/05/08 and
> > > 2001/06/04.
> > > The idea is that the window can't be resized while a client is
> > > connected to it. The reason being that the window is redrawn following
> > > a resize, which requires re-running the commands which were registered
> > > with D_add_to_list, and you can't have multiple clients connected
> > > simultaneously.
> > > It should be possible to resize the window when no client is connected
> > > though.
> > > Also, which window manager are you using? Does the problem go away if
> > > you use a different WM? What does "xprop" say about the window's
> > > WM_NORMAL_HINTS property?
> > > Glynn Clements <glynn.clements at virgin.net>
> > Glynn,
> > The CVS entries from the last build I did on the Sun are from May 21,
> > 2001.
> OK; that predates the introduction of the resize restrictions.
> However:
> > The window manager I am using on the Sun is the dtwm, part of the
> > Solaris install. I do not know the version number off hand, but it is
> > the one packaged with Solaris 7, if that helps.
> > Below is the output from xprops on the monitor ....
> > WM_STATE(WM_STATE):
> >                 window state: Normal
> >                 icon window: 0x3404224
> > _DT_WORKSPACE_PRESENCE(_DT_WORKSPACE_PRESENCE) = 0x101
> > WM_PROTOCOLS(ATOM): protocols  WM_DELETE_WINDOW
> > WM_CLASS(STRING) = "x0", "GRASS 5.0.0pre1"
> > WM_HINTS(WM_HINTS):
> >                 bitmap id # to use for icon: 0x6800002
> > WM_NORMAL_HINTS(WM_SIZE_HINTS):
> >                 program specified size: 450 by 400
> This suggests that the WM ought to allow the window to be resized.
> When resize is (intentionally) inhibited, xprop should show:
>                 program specified minimum size: 450 by 400
>                 program specified maximum size: 450 by 400
> Can you try modifying src/display/devices/XDRIVER/XDRIVER24/Client.c,
> line 22. Currently, it should read:
>         szhints->flags = PSize;
> Settings worth trying include
>         szhints->flags = PPosition | PSize;
                program specified location: 0, 0
> and
>         szhints->flags = USPosition | USSize;
                user specified location: 0, 0
                user specified size: 450 by 400
> and
>         szhints->flags = 0;
> Let me know which of these (if any) work.
Glynn,
I tried the above changes to Client.c.  I have appended the output from
xprop to each change, if that helps. Note that there were no HINTS for
flag = 0.
I was not able to resize the monitor after the abovce changes with the
exception of "flags = 0". In the case of "flags = 0" I was able to
resize the monitor until I drew in it. After that I was unable to resize
it.  The size seems to be getting locked somehow?? Could it be leaving a
lock (??) file somewhere?
For the above changes, I only did "gmake5 -i" in the XDRIVER24
directory. Does anything else have to be rebuilt to pick up the changes?
Bob Covill
Tekmap Consulting
P.O. Box 2016 Fall River, N.S.
B2T 1K6
Canada
E-Mail: bcovill at tekmap.ns.ca
Phone: 902-860-1496
Fax: 902-860-1498
