[GRASS5] nviz script OK
Helena Mitasova
hmitaso at unity.ncsu.edu
Fri Jul 27 16:36:36 EDT 2001
Bob
I think that the script is there - sorry for the confusion - GRASS that did not have
the script
was from march 2001 but it was installed only yesterday by a grad student here - I
think that these older versions should not
be there at all so that people do not report bugs which have already been fixed. I had
people writing
me who have just installed beta11 which is really old.
My older version of GRASS which has the script was from May2001 so that is why I
thought that it
was removed.
I guess that we need to wait for Markus to get back on-line to put things into order.
thank you
Helena
Covill wrote:
> Helena Mitasova wrote:
> > We have just installed GRASS5.00pre1 and it seems that that the nviz start-up
> > script was removed (or never put into release) and
> > nviz is called by nviz2.2 (and path must be given first). The script worked well
> > and was more convenient
> > than the old nviz2.2, I was wondering why it was removed. It was not the cause of
> > the crashes that I still
> > have (both when running nviz2.2 and nviz) and it seems that it is more LINUX7.1
> > problem rather than GRASS.
> > I believe that the script should be put back - or am I just confusing this release
> > with the newer CVS version?
> > thanks,
> > Helena
> > P.S. Just in case that somebody gets nviz crashing his machine randomly we have
> > found that it is happening somewhere
> > in the following part of the code (Bill things that it is togl, but I don't
> > understand these things at all). I am suspicious that it is
> > not a GRASS problem because nobody else seems to have that problem, but it happens
> > under various window managers
> > (KDE, GNOME Sawfish and Enlightment and so far only under LINUX7.1).
> > NVIZ2.2/scripts/nviz2.2_script
> > puts "toplevel made"
> > # make informational text widget
> > set Nv_(text) "Start"
> > entry $BASE.entry -relief sunken -borderwidth 3 -state disabled \
> > -textvariable Nv_(text)
> > place $BASE.entry -relx 0 -relwidth .70 -rely 0
> > ## glxwin $BASE.canvas -rgb true -db true -zbuffersize -1
> > togl $BASE.canvas -rgba true -double true -depth true
> > place $BASE.canvas -relx .01 -rely .03 -relwidth .98 -relheight .97
> > bind $BASE.canvas <Expose> {Nv_expose %W}
> > bind $BASE.canvas <Configure> {set Nv_(height) %h}
> > ## bind $BASE.canvas <Configure> {if [%W islinked] {glx_viewport %w %h; \
> > set Nv_(height) %h}}
> > update
> > # DEBUG
> > puts "info widget made"
> Helena,
> The nviz script should not have been removed from CVS. I think the most
> recent CVS branch is:
> releasebranch_11_april_2001_5_0_0
> If the file has been removed I can re-apply to CVS. My CVS system is
> down right now so I cannot check the status. I will take a look at the
> above TCL code to see where the crashes might be coming from.
> Bob Covill
> Tekmap Consulting
> P.O. Box 2016 Fall River, N.S.
> B2T 1K6
> Canada
> E-Mail: bcovill at tekmap.ns.ca
> Phone: 902-860-1496
> Fax: 902-860-1498
