[GRASS5] Grass monitor library
Glynn Clements
glynn.clements at virgin.net
Sat Jul 28 01:43:39 EDT 2001
pcpa at conectiva.com.br wrote:
> I am implementing a front end to grass, where I am creating my own monitors,
> so that I can layout better my application, can put function buttons around
> the monitor(s) screen(s), etc.
> I believe there are some problems with the current library. Function names
> are not very sugestive :-), it is very easy to get space name problems. But
> the biggest problem is that it uses all around global variables. It should
> have some sort of context, so that the library could manage several monitors
> at once.
> It clearly also needs some better error handling, bounds checking, and at
> least for the code that use fifos, there are several places were it can block
> forever.
> What is the current status of the monitors code at src/display/devices/?
It's now in a state where, once GRASS 5.0 is released, we can throw
the whole thing in the bin and start again from scratch.
Seriously.
Look at the default "monitorcap" file:
#4105:driver/4105:Tektronix 4105: \
If the original architecture was designed with those sorts of
limitations in mind, it's probably had its day.
Basically, src/display/devices and src/libes/raster need to go, with
src/libes/display (and a fair number of programs) being re-implemented
on top of better foundations.
But right now, the priority is to get 5.0.0 out of the door so that
end-users have a single, more-or-less stable version instead of the
moving target of whatever was in CVS at the time. This really isn't
the time for another major change to the existing monitor
architecture.
Glynn Clements <glynn.clements at virgin.net>
