[GRASS5] More on g.region errors
Eric G. Miller
egm2 at jps.net
Mon Jul 30 22:05:29 EDT 2001
On Mon, Jul 30, 2001 at 03:18:40PM -0700, Rich Shepard wrote:
[snip]
> In PROJ_UNITS, the datum is defined as NAD83 and the ellipsoid as clark66.
This is clearly wrong! NAD83 uses the GRS80
ellipsoid. GRS80 is almost identical to the
WGS84 ellipsoid, btw.
> Apparently this is not being brought in with the data by m.in.e00. Where do
> I go to enter it manually? Is this the cause of the problem with expanding
> the bounds?
Despite, the error noted above. I can't say why you're getting garbage
values output (though that G_free() was clearly an error).
Eric G. Miller <egm2 at jps.net>
