[GRASS5] More on g.region errors
Rich Shepard
rshepard at appl-ecosys.com
Mon Jul 30 18:18:40 EDT 2001
I keep getting the same type of error ("default region is P @P @", or
something similar) whenever I try to expand the current region using a
vector file. I don't know in what directory GRASS is looking for the default
region.
Here's the output from g.region -p:
GRASS:/mnt/usr4/projects/nevada/coeur > g.region -p
projection: 1 (UTM)
zone: 11
datum: ** unknown (default: WGS84) **
ellipsoid: ** unknown (default: WGS84) **
north: 4469934
south: 4455924
west: 393671.28124
east: 404501.28124
nsres: 30
ewres: 30
rows: 467
cols: 361
In PROJ_UNITS, the datum is defined as NAD83 and the ellipsoid as clark66.
Apparently this is not being brought in with the data by m.in.e00. Where do
I go to enter it manually? Is this the cause of the problem with expanding
the bounds?
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-responsible mining happen.
