[GRASS5] Silly Gdal Lib Error
Glynn Clements
glynn.clements at virgin.net
Mon Jun 4 21:26:31 EDT 2001
Jeshua Lacock wrote:
> I installed your gdal lib, and when attempting to compile r.in.gdal, I
> get a "Undefined symbols:
> _GBGetSymbol" error.
> Any ideas?
src/raster/r.in.gdal/gbgetsymbol.c contains two definitions of
GBGetSymbol(); one definition is conditional upon
#if defined(__unix__)
while the other is conditional upon
#ifdef _WIN32
It appears that neither of these macros are defined on your system
(clearly it's the first one which should be). The simplest workaround
is to add "-D__unix__" to CFLAGS (e.g. by adding it to COMPILE_FLAGS
in src/CMD/head/head.<platform>).
Glynn Clements <glynn.clements at virgin.net>
