[GRASS5] Jeshua Lacock <jeshua@SierraMaps.com>
Jeshua Lacock
jeshua at SierraMaps.com
Tue Jun 5 03:55:48 EDT 2001
On Monday, June 4, 2001, at 10:24 PM, Glynn Clements wrote:
> For now, I've replaced Old_tty() with endwin() (which is what the
> ncurses manpage recommends when exiting curses "mode"), and removed
> the calls to Old_tty() (refresh() should re-initialise curses) and
> Get_{old,new}_tty() (which aren't required if you don't use
> {Old,New}_tty()).
> I've commited these changes. Can people check that these programs
> still spawn $GISBASE/etc/geo.* correctly on their systems.
Hi Glynn,
Thanks for the fix. After updating, d.colors has now been compiled for
Darwin.
Could you please explain what you mean by "spawn"? And I will test it
here. I assume you mean execute?
Thanks again,
Jeshua Lacock
Cartographer/Owner
http://SierraMaps.com
http://3dTopoMaps.com
Telephone: (760) 935-4481
