[GRASS5] Darwin Pre1 gtty stty errors
Glynn Clements glynn.clements at virgin.net
Thu Jun 7 12:03:42 EDT 2001
Eric G. Miller wrote:
> > These programs fall into five basic categories:
> > 1. False positives (apparently). Most of the listed d.* programs seem
> > to handle the --interface-description flag fine.
[snip]
> NOTE: Each one of these produces a Segmentation fault after outputting
> the description on the command line.
Not here, they don't.
> Maybe we could track down the reason for the Segmentation fault's in
> category 1, as the interface description output seems to fail when
> called from a script.
I don't see it, so I'll need you to track it down.
> > Most of category 4 is going to have to stay as-is for 5.0.0, although
> > some of them might be amenable to "rehabilitation" as command-line
> > programs without too much work.
> I guess a program that would use this mechanism could blacklist
> "category 4" programs...
It might be nice if --interface-description still worked, e.g.
outputting a description which stated that the program was
interactive-only.
There's also the question of whether any of these programs provide
useful functionality which isn't available in any existing
command-line program.
Glynn Clements <glynn.clements at virgin.net>
