[GRASS5] Darwin Pre1 gtty stty errors
Glynn Clements
glynn.clements at virgin.net
Fri Jun 8 01:11:04 EDT 2001
Eric G. Miller wrote:
> > > > These programs fall into five basic categories:
> > > > 1. False positives (apparently). Most of the listed d.* programs seem
> > > > to handle the --interface-description flag fine.
> > [snip]
> > > NOTE: Each one of these produces a Segmentation fault after outputting
> > > the description on the command line.
> > Not here, they don't.
> Do you have a graphics device running?
No. I wouldn't have found the category 2 cases if I had.
> Most of the ones I've looked at have a call to R_open_driver(),
That applies to all of the category 2 cases.
> or don't call G_gisinit() before defining module options (bad).
OK; some of them do call G_define_module before G_gisinit(). However,
I can't see why that would actually cause problems; AFAICT, neither
G_define_module nor G_define_option rely upon anything having been
initialised.
Having said that, if G_gisinit(argv[0]) is meant to be called before
anything else, I'll make changes where necessary.
> > > > Most of category 4 is going to have to stay as-is for 5.0.0, although
> > > > some of them might be amenable to "rehabilitation" as command-line
> > > > programs without too much work.
> > > I guess a program that would use this mechanism could blacklist
> > > "category 4" programs...
> > It might be nice if --interface-description still worked, e.g.
> > outputting a description which stated that the program was
> > interactive-only.
> Depending on the module, this shouldn't be too hard. But, the module
> must have a version in grass5/etc/bin/cmd/ otherwise the front end
> intercepts the command line call with parameters (all that gmakelink5
> line noise stuff).
Maybe front.end could trap the case where --interface-description is
used.
> There's nothing in the grass-interface.dtd to flag
> an interactive or console-interactive module. Perhaps such an addition
> would be useful?
I think so.
I'm not sure if we need to have a function to declare interactive-only
behaviour. It may suffice to test "!n_flags && !n_opts".
Glynn Clements <glynn.clements at virgin.net>
