[GRASS5] Darwin r.fill.dir
Justin Hickey jhickey at hpcc.nectec.or.th
Sun Jun 10 23:26:10 EDT 2001
Hi Jeshua
Jeshua Lacock wrote:
> It appears to me a limitation of the math.h file installed with
> Darwin.
> MAXDOUBLE is not defined, however there there is a MAXFLOAT defined.
> Would it be safe to assign the same vaule to MAXDOUBLE?
> Additionally, MINFLOAT and MINDOUBLE have not been defined.  Is there
> a value that I could assign them?
Since the math library is not part of the standard C library I would
suggest that these constants be changed to those in float.h which is
part of the standard library.
Namely, DBL_MAX, DBL_MIN, FLT_MAX, and FLT_MIN would probably be better
choices.
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
