[GRASS5] Re: [bug #750] (grass) g.manual problem
Justin Hickey jhickey at hpcc.nectec.or.th
Mon Jun 11 21:43:14 EDT 2001
Hi Markus
Markus Neteler via RT wrote:
> here it works fine. Be sure that you have eliminated the (old) binary
> version of g.manual. Check
> which g.manual
> /usr/local/grass5/scripts/g.manual
> that you use the script version. What does
> echo $GRASS_PAGER
> more
> tell you?
The following is a sample run from Grass built yesterday from an update
of the release branch, followed by
make uninstall
make clean
make
make install
Note that this was obtained by selecting the text on the terminal
window, and then pasting it in my mail composer window.
Mapset <PERMANENT> in Location <jhickey>
GRASS 5.0.0pre1 > g.manual -1
GRASS 5.0.0pre1 > which g.manual
/tmp/grass/grass5/scripts/g.manual
GRASS 5.0.0pre1 > echo $GRASS_PAGER
more
GRASS 5.0.0pre1 > g.manual -a
GRASS 5.0.0pre1 >
As you can see, the -1 and -a options do nothing for me. I haven't had
time to look at this yet, any hints on where to start?
Sincerely,
Jazzman (a.k.a. Justin Hickey)  e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do.  ---Anonymous
Jazz and Trek Rule!!!
