[GRASS5] Re: [bug #750] (grass) g.manual problem
Glynn Clements
glynn.clements at virgin.net
Tue Jun 12 02:58:18 EDT 2001
Justin Hickey wrote:
> As you can see, the -1 and -a options do nothing for me. I haven't had
> time to look at this yet, any hints on where to start?
g.manual fails if PAGER is unset:
if [ "$opt1" ]
then
/bin/ls $GISBASE/man/man1 | $PAGER
exit 0
elif [ "$opta" ]
then
/bin/ls -C $GISBASE/man/man1 | $PAGER
exit 0
fi
This needs to be changed to $GRASS_PAGER; presumably the global change
of PAGER to GRASS_PAGER overlooked the scripts.
Glynn Clements <glynn.clements at virgin.net>
