[GRASS5] X monitor resize problem...
Eric G. Miller egm2 at jps.net
Wed Jun 13 21:25:39 EDT 2001
On Wed, Jun 13, 2001 at 01:09:20PM +0100, Glynn Clements wrote:
> BTW, I'm open to comments as to whether the existing behaviour is
> correct. It's arguable that it shouldn't be using the US* flags unless
> the XDRIVER_* environments variables are set. Also, whether to specify
> the position when XDRIVER_{LEFT,TOP} are unset is a matter of
> preference. Personally I'd rather let the WM place it, but this won't
> happen if the program always requests a specific location.
Thanks for the info.  I guess I'll hold off filing a bug report against
blackbox unless I can be sure it isn't responding correctly to the
attribute settings.
Eric G. Miller <egm2 at jps.net>
