[GRASS5] [bug #756] (grass) interaction between r.slope.aspect
and r.flowmd
Rich Shepard
rshepard at appl-ecosys.com
Sat Jun 16 18:42:22 EDT 2001
On Sun, 17 Jun 2001, Request Tracker wrote:
> I have a problem with r.flowmd and/or r.slope.aspect The vector map
> (flout) contains many horizontal lines that go completely across the
> monitor window (obviously junk). This occurs if I run r.slope.aspect and
> have the module calculate both slope and aspect outputs. If I have
> r.slope.aspect calculate just the aspect, the problem does not occur.
> Very strange, it seems that calculating more than one output in
> r.slope.aspect causes errors in the aspect output which r.flowmd cannot
> handle properly.
Erik,
What happens if you use r.flow with a raster DEM and an asect map?
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
2404 SW 22nd Street | Troutdale, OR 97060-1247 | U.S.A.
+ 1 503-667-4517 (voice) | + 1 503-667-8863 (fax) | rshepard at appl-ecosys.com
Making environmentally-responsible mining happen.
