[GRASS5] [bug #752] (grass) configure: doesn't add -lGL -lGLw -lGLUT entries in head file (Solaris)
Glynn Clements glynn.clements at virgin.net
Thu Jun 21 08:30:06 EDT 2001
Markus Neteler wrote:
> even if the cache is disabled, the libraries won't be added.
> Seems to be a coding problem in configure.
Yes, but if the caching is disabled, config.log will include the error
message(s) from the attempt to compile the test program.
Glynn Clements <glynn.clements at virgin.net>
