[GRASS5] [bug #752] (grass) configure: doesn't add -lGL -lGLw -lGLUT entries in head file (Solaris)
Markus Neteler neteler at geog.uni-hannover.de
Wed Jun 20 14:21:29 EDT 2001
On Wed, Jun 13, 2001 at 09:57:22PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > > the "configure" doesn't add -lGL -lGLw -lGLUT in head file on Solaris/SUN
> > > > while this is working on Linux. Similar was reported for MaxOSX recently.
> > > > After adding above entries into head file, everything compiles fine.
> > > > The libraries are detected:
> > > > checking GL/gl.h and GL/GLwMDrawA.h...  -I/usr/include -I/usr/local/include and  -I/usr/include
> > > > checking for glBegin in -lGL... (cached) no
> > > > checking for gluBeginCurve in -lGLU... (cached) no
> > > > checking for GLwDrawingAreaMakeCurrent in -lGLw... (cached) no
> > > > checking for GLwCreateMDrawingArea in -lGLwM... (cached) no
> > > > I have no idea how to fix this (as it works for Linux). Probably
> > > > some wrong variable quoting?
> > > What does config.log say?
> > > After the line:
> > > configure:4226: checking for glBegin in -lGL
> > > there should be the compilation command, along with any error messages
> > > and the source of the test program. The error message(s) should
> > > provide some clues as to why it failed.
> Of course, this was based upon the (mistaken) assumption that
> configure actually performs the test ...
> > It seems there is nothing:
> > configure:4044: checking libpq paths
> > configure:4059: checking for PQcmdTuples in -lpq
> > configure:4183: checking GL/gl.h and GL/GLwMDrawA.h
> > configure:4270: checking for gluBeginCurve in -lGLU
> > configure:4314: checking for GLwDrawingAreaMakeCurrent in -lGLw
> > configure:4354: checking for GLwCreateMDrawingArea in -lGLwM
> > configure:4460: checking for sql.h
> > configure:4496: checking for location of odbc lib
> > configure:4594: checking for jpeglib.h
> > (above of that the curses compile thing is present in config.log).
> > Strange...
> Not really; this is a consequence of configure's caching mechanism.
> Do "rm config.cache", then re-run configure, then check again.
> Better still, add the lines
>      define([AC_CACHE_LOAD], )dnl
>      define([AC_CACHE_SAVE], )dnl
> to the beginning of configure.in (before the AC_INIT), run autoconf,
> then commit both configure.in and configure to CVS.
> This will completely disable autoconf's caching mechanism (which
> basically causes humans to waste countless hours tracking down
> problems in order to allow CPUs to spend more time idle; whoever
> thought that this was a good idea deserves shooting; actually,
> shooting is too good for them).
Glynn,
even if the cache is disabled, the libraries won't be added.
Seems to be a coding problem in configure.
Markus
