[GRASS5] XML fun with --interface-description's...
Eric G. Miller
egm2 at jps.net
Sun Jun 24 13:45:27 EDT 2001
On Sun, Jun 24, 2001 at 05:43:38PM +0200, Bernhard Reiter wrote:
> Eric,
> the output looks quite nice under galeon. :)
> Maybe the red stars and the attributes of the parameters can
> be displayed a little bit more compact.
I'm open to suggestions. Maybe little icons for each of "type",
"required", and "multiple"? I might be able to combine the "default"
and "options" a little too (getting rid of the list altogether). I had
it in tables before which was more compact, but I had left out the
"default" and "options". Having them as table cells was too much, but
maybe I can just squeeze them under the description? I've spent most of
the time fighting with the weird constructs of XSLT and XPATH
languages...
Eric G. Miller <egm2 at jps.net>
