[GRASS5] Re: d.his
Markus Neteler
neteler at geog.uni-hannover.de
Mon Jun 25 13:14:05 EDT 2001
Hi again on d.his,
there is a simple test to see what I mean with "moire patterns":
r.mapcalc map1=44
r.mapcalc map2=100
d.his i=map1 h=map2
I would expect a homogenous color, but there are irregular patterns.
If you use:
d.his i=map1 h=map2 out=his
r.univar his
you will find a range of values although it should be one value overall.
It looks like a precision problem to me.
Markus
