[GRASS5] xdriver: Unable to get sufficient colors
Robert Lagacé lagace at grr.ulaval.ca
Wed Jun 27 09:47:57 EDT 2001
Radim Blazek wrote:
> Glynn Clements wrote:
> > Radim Blazek wrote:
> > > I have fresh devel and stable grass50 here with following problem:
> > > d.mon in stable branch:
> > > d.mon start=x0
> > > using default visual which is PseudoColor
> > > ERROR: Unable to get sufficient colors
> > > No socket to connect to for monitor <x0>.
> > > Problem selecting x0. Will try once more
> > > I have 256 colors only here on KDE2.1/RH7.1.  It starts OK in devel branch.
> > Has the colourmap been consumed by existing clients? Does the problem
> > occur if the monitor is the only program running using the display?
> Thanks. It works after X restart. No other program was running (except console), I know that
> problem. It seems that if konqueror (other apps?) is started and closed, its colors are still in use.
> Radim
> grass5 mailing list
> grass5 at geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/grass5
Can we avoid the color problem using a private color map as it is possible in
Netscape (using the command nestcape -install) ?  Doing that, GRASS can use any
color with only a drawback, the other appliactions get bizare colors when not
focus.
Robert Lagacé, professeur
Pavillon Comtois
Université Laval
Ste-Foy, Québec, G1K 7P4
tel : (418)-656-2131#2276
Fax : (418)-656-3723
E-mail : lagace at grr.ulaval.ca
