[GRASS5] xdriver: Unable to get sufficient colors
Radim Blazek
Radim.Blazek at dhv.cz
Wed Jun 27 06:28:35 EDT 2001
Glynn Clements wrote:
> Radim Blazek wrote:
> > I have fresh devel and stable grass50 here with following problem:
> > d.mon in stable branch:
> > d.mon start=x0
> > using default visual which is PseudoColor
> > ERROR: Unable to get sufficient colors
> > No socket to connect to for monitor <x0>.
> > Problem selecting x0. Will try once more
> > I have 256 colors only here on KDE2.1/RH7.1. It starts OK in devel branch.
> Has the colourmap been consumed by existing clients? Does the problem
> occur if the monitor is the only program running using the display?
Thanks. It works after X restart. No other program was running (except console), I know that
problem. It seems that if konqueror (other apps?) is started and closed, its colors are still in use.
Radim
