[GRASS5] GRASS 5.0.0 branch question
John Huddleston jhudd at lamar.colostate.edu
Fri Mar 30 08:45:17 EST 2001
Good morning Markus,
Whenever you update files on your local system with the -r
option, it is like a checkout from the repository with that
TAG.  As such, "cvs update -r releasebranch_5_0_0"
brings out that code and places a sticky tag in the CVS/Entries
files.  Look at one as an example.  You'll see a
Treleasebranch_5_0_0 at the end of each line.
cvs --help update    gives the options and shows that
the -r and -D checks out code as sticky
Use the cvs update -A to release the Tag
Use the command
cvs commit -m "comment" -rreleasebranch_5_0_0 REQUIREMENTS
to commit the REQUIREMENTS file to the branch
That help?
John
----- Original Message -----
From: "Markus Neteler" <neteler at geog.uni-hannover.de>
To: "grass5 developers list" <grass5 at geog.uni-hannover.de>
Sent: Wednesday, March 28, 2001 1:49 AM
Subject: [GRASS5] GRASS 5.0.0 branch question
> Hi CVS gurus,
> it seems I need an advice:
> I have created the release branch recently (at least I think so):
>  1. tagging the sources
>  2. checking out this tagged version into new directory
>  3. applying
>         cvs tag -b "releasebranch_5_0_0"
>     here
> Like that the branch should have been created (as far as I understand the
> CVS book).
> To upgrade my second copy to this branch, I used
> So far, so good (?).
> Now I want to apply a change from exp/main tree to this release tree, but
> I get
>  cvs ci -m"updated" REQUIREMENTS  # I simply copied this file from exp tree
>  cvs server: sticky tag 'releasebranch_5_0_0' for file 'REQUIREMENTS' is not a
> branch
> cvs [server aborted]: correct above errors first!
> What's that?
> Thanks for any help,
>  Markus
> PS: I try to interpret now:
> http://www.loria.fr/~molli/cvs/doc/cvs_5.html#SEC49
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
