[GRASS5] Recommended tweak for 5.1
Markus Neteler
neteler at geog.uni-hannover.de
Fri Mar 30 09:18:19 EST 2001
On Fri, Mar 30, 2001 at 03:21:03PM +0200, Radim Blazek wrote:
> v.[in|out].dxf should be rewritten to work on binary vector and
> merge v.in.dxf, v.in.dxf2 and v.in.dxf3d. I think that we should use
> some dxf library (to support new dxf versions). Does anybody know about
> some GPL dxf library in C? I have found only http://omega.sim.no/coin3d/dime_about.xml
> which is C++.
> All for grass51.
Hi Radim,
not very promising, but there is also:
o http://dxflib.sourceforge.net/ (however, C++)
o http://www.iserv.net/~strdream/jeff/programs/ (unsupported?)
o Maybe: OGR Simple Features Library (the server is currently unreachable)
Frank Warmerdam might write a C API once for it (not sure)
Sorry, not too much of help,
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
