[GRASS5] [bug #230] (grass) Seg fault in r.report (fwd)
Roger Bivand
rsb at reclus.nhh.no
Wed Mar 28 04:07:15 EST 2001
Markus & friends:
This is a forwarded copy of a bug report I filed yesterday in the 26 March
CVS snapshot. It feels as though something has changed in a library that
r.report calls and r.stats doesn't. I don't think it's an LZW vs. z issue,
because leics/lancov is Data Type: CELL. I'm also afraid it's release
critical.
Roger
PS. I think r.mask is dumping core too, and doesn't seem to be working; it
is working on a beta8 I still have running.
Roger Bivand
Economic Geography Section, Department of Economics, Norwegian School of
Economics and Business Administration, Breiviksveien 40, N-5045 Bergen,
Norway. voice: +47 55 95 93 55; fax +47 55 95 93 93
e-mail: Roger.Bivand at nhh.no
and: Department of Geography and Regional Development, University of
Gdansk, al. Mar. J. Pilsudskiego 46, PL-81 378 Gdynia, Poland.
---------- Forwarded message ----------
Date: Tue, 27 Mar 2001 15:35:19 +0200 (CEST)
From: Request Tracker <grass-bugs at intevation.de>, grass5 at geog.uni
To: Roger.Bivand at nhh.no
Subject: [bug #230] (grass) Seg fault in r.report
this bug's URL: http://intevation.de/rt/webrt?serial_num=230
Greetings,
This message has been automatically generated in response to your
message regarding "Seg fault in r.report", the content of which appears below. There is
no need to reply to it now. Request Tracker has received your message and
it has been assigned a ticket ID of [bug #230]. Please
include the string
[bug #230]
in the subject line of all future correspondence about this
problem. To do so, you may reply to this message.
Thank you,
Request Tracker
Subject: Seg fault in r.report
Platform: Linux/Intel
Linux distro:: RedHat
linux cpu:: Intel (i486, i586, pentium ...)
Xwindows version:: Xfree 3.3.6
Xwindows manager:: GNOME
TclTk version:: tcl/tk 8.0.5
grass downloaded at:: Hannover site
grass binary for platform:: I compiled the sources myself
grass sources source:: no, I got a source code package from the server, cvs snap 26 Mar
c compiler name:: gcc
r.report exits returning 1 in $? and prints no output, dumping core.
I tried to use gdb to see what is going on, but there are no debugging
symbols in the executable. r.report from previous betas etc worked,
including GRASS 5.0beta11 (February 2001) downloaded 27 February.
r.stats -cl <maplayer> works OK, but r.report <maplayer> units=c now
fails. The gdb output was:
(gdb) run landcov
Starting program: /usr/local/grass-5.0/grass5/bin/r.report landcov
(no debugging symbols found)...
Program received signal SIGTRAP, Trace/breakpoint trap.
0x400019a0 in _start () at rtld.c:142
142 rtld.c: No such file or directory.
(gdb) n
Program received signal SIGSEGV, Segmentation fault.
0x4000c683 in _dl_sysdep_start (start_argptr=0xbffff790,
dl_main=0x4000221c <dl_main>) at ../sysdeps/generic/dl-sysdep.c:95
95 ../sysdeps/generic/dl-sysdep.c: No such file or directory.
-------------------------------------------- Managed by Request Tracker
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
