[GRASS5] GRASS 5.0.0 branch question
Markus Neteler
neteler at geog.uni-hannover.de
Wed Mar 28 03:49:56 EST 2001
Hi CVS gurus,
it seems I need an advice:
I have created the release branch recently (at least I think so):
1. tagging the sources
2. checking out this tagged version into new directory
3. applying
cvs tag -b "releasebranch_5_0_0"
here
Like that the branch should have been created (as far as I understand the
CVS book).
To upgrade my second copy to this branch, I used
cvs update -r releasebranch_5_0_0
So far, so good (?).
Now I want to apply a change from exp/main tree to this release tree, but
I get
cvs ci -m"updated" REQUIREMENTS # I simply copied this file from exp tree
cvs server: sticky tag 'releasebranch_5_0_0' for file 'REQUIREMENTS' is not a
branch
cvs [server aborted]: correct above errors first!
What's that?
Thanks for any help,
Markus
PS: I try to interpret now:
http://www.loria.fr/~molli/cvs/doc/cvs_5.html#SEC49
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
