[GRASS5] Re: installation/compiling instruction for GRASS on
Eric G. Miller egm2 at jps.net
Tue Mar 27 23:46:36 EST 2001
On Wed, Mar 28, 2001 at 01:59:45PM +1000, Mike Thomas wrote:
> Hi Malcolm.
> > I will test again on Win98.  I had suspected the fork() implementation.
> My memory is that I wasn't able to get the CELL driver working on '98 at the
> time, which backs up your suspicion!
> I can imagine that given the complexity of the Grass drivers compared to a
> small test program, it may well still be fork().  I was reading about how
> the Cygwin people implemented fork() yesterday and it sounds dodgey.  Maybe
> Grass does something relating to program state that the test program doesn't
> highlight.
> I tried different socket communication modes for the CELL driver, without
> success, in case it was sockets causing the problem.
So, the Xdriver works but the CELL driver doesn't?  My understanding is
the fork() call may be the problem.  Under all the GRASS drivers, there
is a call to fork() followed by the parent process exiting with the
child left running.  However, if fork() fails, the driver will exit.  Do
you get any error messages that might give a clue?  Does the process
hang or just exit or what?
Also note, a failure report from d.mon that it was unable to set-up the
communications channel to the driver does not necessarily mean the
driver failed to start.  Right now, there is a little timing problem
with the server getting to a listening state before d.mon gives up
trying to say "hi!".  I've seen this problem more frequently with the
CELL driver as it seems to have a longer start-up cycle than the
Xdriver.  Anyway, if this is remotely possible then after d.mon reports
failure, just rerun it with "d.mon select=CELL".  I suspect that the
Cygwin fork adds even more overhead/slowdown for the driver than it
would otherwise have on *nix (where fork is pretty lightweight).
Anyway, I hope to hack a little on d.mon shortly to make it wait a
little longer or try a few more times to connect before giving up.
Eric G. Miller <egm2 at jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
