[GRASS5] why GPL
strobe anarkhos
anarkhos at mac.com
Tue Mar 27 06:24:44 EST 2001
>> What is the distinction? In all cases you need to know the
>> interface.
>One rule of thumb is:
>How much depends the software on the GPLled software.
>If it can be run with other software then it can be seen as a
>non-derived work.
Well this just complicates issues. For example you can create a mutable array of vectors which uses the same methods as NSMutableArray. Now I can take that object and treat it like any NSMutableArray object. I don't even have to cast the object type.
Now mentally I know I'm editing a vector set, but the code doesn't have to refer to a GRASSVectorSetMutableArray or whatever, just a generic object or an NSMutableArray.
Now does that make my code derived work?
The GPL may be stricter, but it's also more vague. At least with the LGPL I know that linking is legal, with the GPL I don't have a clue what's legal.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
