[GRASS5] solaris
Markus Neteler neteler at geog.uni-hannover.de
Tue Mar 27 03:05:32 EST 2001
Helena,
On Mon, Mar 26, 2001 at 11:39:16AM -0500, Helena Mitasova wrote:
> We have made another attempt to compile the  CVS version on Solaris -
> this time it is giving different errors and unfortunatelly it still does
> not
> compile - this is probably more Solaris problem rather than GRASS
> problem
> the error and config log files are at
> http://www2.gis.uiuc.edu:2280/modviz/temp/solaris.compile
> If you see anything obvious, please let us know,
Yes, I think so:
configure: In function 'main':
configure:2565: structure has no member named 'maxy'
configure: failed program was:
#line 2559 "configure"
#include "confdefs.h"
#include <curses.h>
  WINDOW w;
int main() {
w.maxy = 0;
; return 0; }
This indicates problems with your curses library. Bob Covill had similar
problems and fixed them by upgrading to ncurses5.
A wish: If src/libes/gis is failing, please send the local error as
well
cd src/libes/gis
gmake5
Most other errors will be related to the missing libgis.a.
So, please upgrade the oldish curses on Solaris to ncurses5.
Regards
 Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
