[GRASS5] compiling CVS on IRIX and Win32/Cygwin
Andreas Lange
Andreas.Lange at Rhein-Main.de
Mon Mar 26 05:37:52 EST 2001
Hi Bob,
thanks for your reply.
But its not the dash. Same happens with data without a dash.
I think it is a more general library problem, but will test again.
Andreas
Bob Covill schrieb:
> Hello,
> Will NVIZ start in quick mode for you (-q). This would tell us if there
> is a problem with the executable or a data loading problem. Also, you
> might try renameing the DEM file to something without a dash (-). In the
> past I have found filenames with dashes can be a problem.
> Hope this helps.
> Bob Covill
> Tekmap Consulting
> P.O. Box 2016 Fall River, N.S.
> B2T 1K6
> Canada
> E-Mail: bcovill at tekmap.ns.ca
> Phone: 902-860-1496
> Fax: 902-860-1498
> If you want to unsubscribe from GRASS Development Team mailing list write to:
> minordomo at geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
Andreas.Lange at Rhein-Main.de - A.C.Lange at GMX.net
