[GRASS5] compiling CVS on IRIX and Win32/Cygwin
Vincent Heurteaux
v.heurteaux at tour-du-valat.com
Mon Mar 26 04:12:56 EST 2001
Bob Covill wrote:
> Andreas Lange wrote
>> (file "/usr/local/grass5/bin/nviz2.2" line 92)
>> Finished - press RETURN or ENTER to continue
> Hello,
> Will NVIZ start in quick mode for you (-q). This would tell us if there
> is a problem with the executable or a data loading problem. Also, you
> might try renameing the DEM file to something without a dash (-). In the
> past I have found filenames with dashes can be a problem.
> Hope this helps.
I've got the same message.
I'm using the current CVS source code compiled with gcc-2.95 on a Debian
potato/i386.
It returns me this error with "elevation.dem" from the spearfish
dataset, so I think dash is not the problem...
hope this helps too.
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
