[GRASS5] Re: r.poly update
Markus Neteler
neteler at geog.uni-hannover.de
Mon Mar 26 03:23:18 EST 2001
Hi Andrea,
hi all,
(cc to grass5)
On Mon, Mar 26, 2001 at 08:16:31AM +0200, Andrea Aime wrote:
> Markus Neteler wrote:
> > On Fri, Mar 23, 2001 at 04:40:43PM +0100, Andrea Aime wrote:
> > > Hi Markus,
> > > here you will find my modified version of r.poly. I'm not sure about
> > > it, but I think that only bound.c changed.
> > Thanks, the file is in CVS now (was the island/label fix, is that right?).
> Yes, but another fix is required as soon as something is decided about
> the use of zero values as vector categories
I need a recommendation of the others here...
(see:
http://www.geog.uni-hannover.de/cgi-bin/minorweb.pl?A=READ&L=grass5/2001/3/12/11
> PS: as I'm playing with GRASS sources I've noticed in head.in that you
> specify -g as a compiler flag (that produces debug symbols) and then -s in
> the linker flags, that strip away any debug symbol. Would it be possibile
> to specify some flag to gmake5 in order to obtain a debug build (maybe
> with -ggdb flag that produces best debug information for the GNU debugger)
> and then maybe no flags for a production build (what about optimizations?
> computation intensive software can gain up to 30% speed-up with the proper
> compiler optimizations).
Currently I don't know how to tell configure to use
-O2
instead of
-g
I have checked configure.in, the related line seems to be line 26
AC_PROG_CC
Obviously something needs to be predefined for selecting -O2 on default?
Markus
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
