[GRASS5] Tag test 2
Justin Hickey
jhickey at hpcc.nectec.or.th
Thu Mar 22 03:28:24 EST 2001
Hi Markus
Ok, I tested this and there are a few errors to report. First
src/raster/r.in.gdal requires a -shared option to the link line to
compile. This is a MIPSPro compiler option so I don't know if r.in.gdal
would compile properly on SGI with gcc. Also, I'm not sure just how to
handle this. I suppose this should be connected to configure somehow,
but I'm not sure how. If all else fails we can add a note in the INSTALL
file for SGI MIPSPro users.
Second, src.contrib/GMSL/NVIZ2.2 failed with the following error:
src/CMD/gmake5.0 src/libes/libimage
src/libes/libimage - directory not found
*** Error code 1 (bu21)
GISGEN failure at STEP: src.contrib/GMSL/NVIZ2.2
Third, src.garden/answers/src.answers/raster/r.fill.dir failed with the
following error:
src/CMD/gmake5.0 ../r.direct
./r.direct - directory not found
GISGEN failure at STEP: src.garden/answers/src.answers/raster/r.fill.dir
I don't know about these ones.
Other than that, grass runs and renders raster and vector files. But
that's all I tested. Hope this helps.
Sincerely,
Jazzman (a.k.a. Justin Hickey) e-mail: jhickey at hpcc.nectec.or.th
High Performance Computing Center
National Electronics and Computer Technology Center (NECTEC)
Bangkok, Thailand
People who think they know everything are very irritating to those
of us who do. ---Anonymous
Jazz and Trek Rule!!!
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
