[GRASS5] Re: [GRASSLIST:1658] Re: r.in.gdal - new libgdal.1.1.so
Frank Warmerdam
warmerdam at pobox.com
Wed Mar 21 10:28:01 EST 2001
Markus Neteler wrote:
> Frank, there might be a related problem due to the
> libstdc++-libc6.2-2.so.3
> stored in
> $GISBASE/lib
> for libgdal.
> Several people have reported this error:
> BUG IN DYNAMIC LINKER ld.so: dl-version.c: 210: _dl_check_map_versions:
> Assertion 'needed != ((void *)0)' failed!
> for nviz and r3.showdspf. I am not sure about this bug, but can it be
> caused by the LD_LIBRARY_PATH? Probably nviz catches the wrong libstdc?
> There seems to be a time coincidence with us adding the LD_LIBRARY_PATH into
> $GISBASE/etc/Init.sh and above bug.
Markus,
Does this problem go away if the libstdc .so is removed from $GISBASE/lib?
Are nvis, and r3.showdspf C++ programs?
The c++ library is only required within $GISBASE/lib if it isn't available
on the system. I thought it would be pretty harmless to include under the
assumption it should be essentially the same as system provided copies, but
I could be wrong. Perhaps we should "hide" the c++ shared library and only
have users rename it to the real name if it turns out they need it.
Best regards,
light and sound - activate the windows | http://pobox.com/~warmerda
and watch the world go round - Rush | Geospatial Programmer for Rent
If you want to unsubscribe from GRASS Development Team mailing list write to:
minordomo at geog.uni-hannover.de with
subject 'unsubscribe grass5'
